I was looking for some stuff to muck around with using some Gels a few months back, and shot a few frames like this:
If I redid them, I'd drag the shutter a little longer to get some more ambient glow on the candles.. I'd also fix the WB in the pics I posted
lol...
To help with focus, I used a Torch...
A tripod of course is a must if there was no strobes - but I ended up shooting this at Flash-Sync so it would have worked hand held as well...
Quickest way to 'get close' would be set to Spot Meter, center over the 'warm glow' you want to capture, and then take a shot and chimp it.... adjust as necceasry...
Using the "Green Button" setup to TV Shift in Manual could be a rapid way to knock in a 'first pass' and then easily adjust things as needed...
