Originally posted by KierraElizabeth Thank you all for your advice!
It seems that my understanding of color casting is faulty from the beginning then? To clarify--color casting is something that occurs throughout the photo because of an ambient problem or mechanical/software issue?
I was assuming that color casting could be limited to an area in a photograph...like grass or clothing affecting the tone of someone's skin as it reflects.
Thank you I'mtheguy and adpo for the helps! And JohnBee (you aren't by any chance in AZ are you?), love that edit. That is a yummy looking red on that barn you have managed there and the legs look just like what I was shooting for!
You're very welcome. And I don't think you're wrong with your definitions either.
However, since color casting is most commonly referred too globally and less commonly addressed locally. This means most adjustments and methods pertinent to color casts(which seek to balance a scene) would not work effectively in this particular case.
BUT... this is by all intended purposes & definition a "color cast" as you yourself said. It's just not the a-typical type most commonly dealt with in photographs.
As for the red barn color, I achieved this with yet another plugin(yep I'm a fan of laziness
) called "
Perfectly Clear" which I've been using over the years as a substitute for manual curve adjustments. And some would call me lazy, but hey... I've put in my time with Photoshop(15 years) and so I think I've earned the right to be lazy.
But that first plugin called
iCorrect is the only utility(that I know of) that can locally adjust color casts on skin of flesh tones.
Hope this helps.
PS. Oh and I don't live in AZ(sorry), unfortunately, I am stuck on some remote island out in Atlantic Canada. - thank goodness they have internet here!
