11-28-2007, 02:17 PM   #16
JF: can you post the table with more resolution? I tried to blow it up in PS and I can't read the small letters.
To stop action in a sunny day, we used this formula when I was in school: F16-1/250. The more light, the faster you can shoot (1/500, etc) Also, dont forget that flash also freezes movement.
Gus
11-28-2007, 03:01 PM   #17
Gaelen's Avatar
Ok well heres a bit to think about
If you want something like this picture
you will have to shoot at a slower speed and follow the object at the same speed its moving
If you just want to stop it
Like this (not the greates example as he wasnt moving very fast)
Then you will have to up the speed
Hope this helps you at least a bit
camera, movement, photography, shutter
New Pentax KX, problem with double shutter movement leading to underexposure Tricerator Pentax DSLR Discussion 21 10-30-2011 09:01 PM
Shutter speed on K-x CrabShadow Troubleshooting and Beginner Help 7 08-14-2010 06:46 AM
what shutter speed did i use? pete_pf Pentax SLR Lens Discussion 9 10-20-2009 01:45 PM
Shutter Speed comovartia Pentax DSLR Discussion 3 12-20-2008 10:38 AM
Shutter speed?! seymop Pentax DSLR Discussion 4 10-02-2007 07:28 PM
All times are GMT -7. The time now is 02:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
