07-22-2011, 03:49 PM   #1
Pentax Pinhole Images
I just got my first pinhole body cap today. Here is a test image I shot with my K20D.
I'd love to see pinhole images from everyone.
PENTAX K20D  Photo
07-22-2011, 03:54 PM   #2
This is cropped a bit - from a K100D 0.30mm pinhole, ~50mm focal length
Looks like similar image quality to me - right about what theory predicts.
Dave
07-22-2011, 04:05 PM   #3
Indeed. Mine is also an 0.3mm, which I believe results in an aperture around f168. I'm excited to start working with the depth of field.
07-22-2011, 05:15 PM   #4
Bad LBA case
Douglas_of_Sweden's Avatar
The problem with pin hole lenses is that they can't be coated.
Thinking of it...with no glass, there can't be any flare...
Pinholes are fun, but hard work. Haven't done it since film days.
07-22-2011, 06:23 PM   #5
RioRico's Avatar
After I got my K20D AF360 DA10-17 DA18-250 FA50 kit, my first optical purchase was... [/me opens the envelope...] a bodycap pinhole. Disappointed the hell out of me. I have shots of fuzzy backgrounds highlighting sharp dust. On my cam it's effectively 45/180, and it lets dust in, so I have to blow the sensor every few minutes. Images are fuzzy because that's WAY past the diffraction limit on a APS-C frame. And it's ~45mm because it can't get any closer to the frame. Did I mention dust? It's horrible in a dusty environment. Use it in heavy rain or total vacuum only.
I love pinholes, I really do. I have a nice handcrafted wooden 6x9cm MF pinhole cam that delivers nicely. (Thanks, Sis!) I've made more than a few oatmeal-carton pano pinhole cams, loaded with 8x10in photo paper. I've seen images shot with very small and very very large pinhole cams. But on a camera with an SLR mirror box and a frame smaller than 135/FF, it's just not worth it, not unless you're really really into dusty impressionistic blobs. A pinhole on a Leica-M or Fed-5 or Argus-C3, fine. A pinhole on an APS-C dSLR, no.
(I've posted ideas for very very very large pinhole cams. I'll try to dig those up.)
04-04-2012, 09:02 PM - 2 Likes   #6
Maybe to late...just spent some time today to make a pinhole for my K20D...:-)...here it is the picture post processed in ps3.
I managed to make it with variable focal distance...so mine is roughly from 28-35 to 50-55 mm...
The hole is really small...
The picture was taken from 30-35 cm, 20 sec.exposure time at 400 ISO...
PENTAX K20D  Photo
04-05-2012, 01:02 AM   #7
Very cool. I have misplaced my pinhole cap.
04-05-2012, 06:45 AM   #8
RioRico's Avatar
QuoteOriginally posted by Vasyl Quote
Impressive picture! Much better than any I've managed. How did you build it with variable focal length?
04-06-2012, 01:21 PM - 2 Likes   #9
Variable focus trick
Here it is what I did...the trick is to make the holder flexible and strong enough to keep it bent in the bayonet...
and some pictures
PENTAX K20D  Photo
PENTAX K20D  Photo
04-06-2012, 02:07 PM   #10
and some pictures
Yow! The first photo is incredibly sharp near the trees! I don't understand how it can be so sharp. Can you tell us more about the conditions like actual focal length & pinhole diameter? Did you post-process the image?
04-06-2012, 03:27 PM   #11
Thank you.
Yes, I post-processed all of them. The first one is a stiched panorama of 6 shots. The distance to the roots was around 2 meters...I do not know what the actual focal length was/is, because the holder is a flexible material and the focal distance depends on how much I will bend it either inside or outside.
Do not ask me about the pinhole diameter....:-)...I just followed the instruction found in here...https://www.pentaxforums.com/forums/photographic-technique/112981-pinhole-photography-k10d.html
I drilled through the cardboard by holding my finger from the aluminum foil side, when I felt the tip of the needle I stopped...then I grinded the foil...
04-09-2012, 09:19 PM   #12
Here it is some picture to show the hole size...the pin looks like a nail, but it is still the pin.
PENTAX K20D  Photo
02-25-2013, 01:48 PM   #13
Scootatheschool1990's Avatar
Wow! Awesome images!!
camera, images, photography, pinhole
People Homemade Pinhole Self Portrait Tomzee93 Post Your Photos! 7 12-06-2018 07:45 AM
Download your pinhole Hassleblad here! JohnBee Non-Pentax Cameras: Canon, Nikon, etc. 2 04-05-2011 07:48 AM
Potential New 11mm Pinhole cap(?) for Micro 4/3 cameras pxpaulx Non-Pentax Cameras: Canon, Nikon, etc. 3 01-28-2011 07:44 PM
Pinhole photography with K10D GlumGrum Photographic Technique 11 09-05-2010 09:31 AM
Pentax k7 and Skink Pinhole Adaptor joshmas Pentax Camera and Field Accessories 7 11-14-2009 10:15 AM
All times are GMT -7. The time now is 12:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
