Originally posted by maltfalc: do you have long exposure noise reduction turned on?
Wasn't aware of this setting. Dug out the manual, and found out where it was, and yes it seems it was on. A lot of the astrophoto tutorials suggest turning any in camera NR off, so I'll see if there's any difference with it off.
Originally posted by calsan: Need an equatorial mount.
Only if I want to use Bulb and have the stars stationary. It's something I'm looking at for the Spotmatic II.
Originally posted by Montoya: Did you by chance take a dark frame after taking this photo?
I've tried it a couple of times (save to 32 bit TIFFs, layer dark frame above shot, set dark layer to Difference) but it seems to have minimal effect.
Quote: I'm an astrophoto guy and had a k100Ds and I can tell, although I love this camera, it is not veyr fit for astrophoto.
It always make a lot of noise (I tried whithout NR and then apply a dark but not enough) and banding.
But still, in your case, I would try to reduce the iso to 400, disable NR, make a dark and stack several image together,
in my case, now, I have K5 and it's like night and day.
But anyway, in general for astrophoto, you need to pp your pictures, they'll never look very nice without proper processing.
Funny you should mention banding, because I found quite a bit in this shot:
As far as PP goes, I lose heart (and admittedly, patience) when I see this much noise. I'm a graphic designer by trade, but even these are beyond my capabilities. The most improvement I've seen is with a image stack, but there's only so many you can stack and realign before the movement in the sky is too great.
Hopefully I can find a sweet spot setup-wise that minimizes the damage.
