Originally posted by NYpHoToGraphEr My computer just died. (snip)
Before going through all the effort of removing the drive, have you tried other options? First, since you were recently working inside the computer, I agree with what another said about checking the internal connections and reseating the various cards. Of course, to prevent damage to those components from static, make absolutely certain you're well grounded before doing anything inside the computer (and make sure the computer is off and unplugged).
Next, you could try reinstalling the computer's BIOS software. This can often be found on the manufacturer's website. If not, request a copy from the manufacturer. Make sure to follow the installation instructions carefully as a mistake with this could really mess up your computer. Reset the BIOS afterwards and then make sure the various settings in that BIOS are correct. Try the defaults first. If the situation is resolved, you can try the optimized settings later.
Next, you could try the original Windows CD. If the installer on that CD doesn't immediately find a hard drive, it will do a slightly deeper search occasionally finding a drive the computer's software missed. If the Windows CD does find that drive, immediately do a repair installation of Windows. A repair installation is not the same as a normal installation, which will overwrite all data on the drive. As long as the image files are intact on the hard drive, a repair installation will not overwrite them.
Finally, at this point, you can go two different directions. You could accept Marc's offer (a wise decision) or search the internet for more drastic solutions for getting a non-functioning drive to work. There are boot floppies & CD's, for example, which attempt to repair the core routines on a standard hard drive. There are no guarantees any of these will work, and some might even make the situation worse. In other words, proceed in this direction at your own risk.
stewart
