Originally posted by sany Does focussing in the eye critical even at smaller aperture (higher f number) since the DOF is more can we not simply focus anywhere on the subject that anyway will have the eyes included in focus?
When there is thin DOF eyes could be a target so the even if the corners loose sharpness the subject would look compromising - is this statement right!?
Yes - but I think the logic behind focusing on the eyes means the DoF will be a lot more 'natural' given that at 70mm's (im gussing common Portrait Focal length) 'roughly' 54% in rear, 46% in front. This means that their Eyes, and NOSE, will definately be in focus, and then it will naturally taper out as it moves to the back of the person.
Focusing on say... the back of their Shoulder.. may bring their eyes into focus, and even their nose - but then you'll have a big chunk 'behind' them also in Focus... and remembering that at 70mm, with a focus distance of say 3m's, you've got only a whopping 40cm's of DOF to 'play with'... at F4. Thats 25cm's 'behind' and 15cm's "in front"... not a lot of room for error really..
You dont want to go much higher than F9, because you'll loose sharpness due to Diffraction....
I lift my suggestion from
Understanding Depth of Field in Photography
I'm sure however someone with more of a clue will be along shortly to restate the above...
