How about this - from The Luminous Landscape:
Quote
Definition: "The closest point of focus at a given aperture, at which infinity falls within the Depth of Field."
From the link
DOF
The article is a very good read on the basics of DOF (where hyperfocal distance comes from anyway)
As SpecialK stated - so called "modern" lenses do not have DOF scales - one of the most stupid things lens manufactures have done. With AF being the rage - "modern" photographers do not grasp the idea of selecting what is in focus - they let the lameoid camera determine what is the point of interest in the image.
edit:1
Try out
Hyperfocal Distance and Depth of Field Calculator - DOFMaster - this tool will let you "play" and after reading about DOF and hyperfocal distance calculations --- you can create what Pentax and other lens manufactures have removed --- a real DOF scale so you can set it manually - just like the good old days. But if you have AF coupled to the shutter button - all bets are off - you are screwed.
edit: 2
Try this site too - the tutorials here are something you just have to go through - you will not be disappointed.
Understanding Depth of Field in Photography
edit: 3
Just go here - read - learn - it is fun
Depth of field and diffraction
The Elitist - formerly known as PDL
