Originally posted by Tingchaleun I got pass step 12...
So did you get all the way through or are you stuck on another spot now? For those that got stuck on the same steps, step 7 is under the channels palette. It should be another tab in the same spot as your layers palette. In color mode the channels are red, green, and blue. In lab mode they are lightness, a, and b. This is also how I sharpen my pictures, when I do sharpening I would rather do it just on the lightness because it can usually find edges better. So just selecting lightness will basically show you a black and white image. For step 12 the adjustment layer is in your layers palette, it is at the bottom and is a circle that is half white half black, if you click on that, to add a new adjustment layer, it will show several different types of adjustment layers to choose from, in this case you want to choose solid color.
I will have to give this a try when I get home. I normally do some of these steps when converting, but not quite the same way.
