Each lens.
Lenses and cameras are made to +/- tolerances. What the adjustment is allowing is you to match (or closely match) those tolerances.
Unfortunately you'll sometimes find lenses and cameras at the same (extreme) tolerance range, either + or - , in which case you might not be able to 'match' them.
That said, Pentax can do it for you, for a particular lens/camera combo, but that could result in all your other lenses being outside adjustment range.
This is also the reason some buyers will change lenses until they get what they regard as a 'good copy'.
You should also be aware that there is a so called 'hack', (it's not, but that's what will come up in a search), that enables the 'hidden' menus in the camera that are used by technicians, etc. One of the results is an improved , ie bigger, range of AF adjustments.
You'll find threads on here referring to the 'hack'.
