Originally posted by veato Anyone got any experience of extreme macro (on the cheap!)
https://www.pentaxforums.com/forums/pentax-lens-articles/152336-cheap-macro-b...lose-work.html Quote: This at the moment is a theoretical question (as I don't own all the items --- yet!) but if your camera bag consisted of the following which would be the most useful item or combination of items for some extreme macro?
1) Tamron 90mm SP Di Macro
2) Cheap manual extension tubes 9, 16 and 30mm
3) Pentax SMC-M 50mm f/1.7
4) Various reversing and coupling rings
You get the cleanest macro (least optical degradation) with extension (tubes and/or bellows) especially with a reversed lens. You get the most extreme macro by reverse-stacking a short prime onto a long prime; a 200mm on the camera with a 25mm stacked on it gives 200/25= 8:1 magnification. Or stack a 28mm on that 90mm for ~3:1 mag, more with the 90mm extended. Any lens reversal means you must work very close, about 45mm with Pentax-type lenses.
With what you've listed, you'll get ~1:1.5 magnification with the 90mm lens fully extended on your 55mm of tubes. Whether 1.5x is extreme is up to you. Get another set of tubes, mount the M50 on both sets, and you'll get ~2:1 magnification. Remember than a non-reversed lens can't focus closer than its focal length (to the optical center of the lens) and that's where the magnification is greatest. So the 50mm lens has a close-focus of 5cm and the 90mm at 9cm. Closer/shorter (and more magnification) is better for studio work; further/longer (and less mag) is better for field work.
How 'extreme' you go depends on where you'll be working, your tripod/rail setup, lighting, etc. See the article for suggestions. Have fun!
