Originally posted by ruemiser Leo,
Thanks. So am I correct in assuming here that because there is already such high Infrared blocking on this camera, that the extreme red experienced in my exposures is a result of this?
On the K100 for example, will the outcome of the same type of exposures with a R72 filter yield raw photos with less Red in the shot? ...
I think you are stating it backwards. Your K10D has less red reaching the sensor due to a stronger filter. I don't have that model, but many on this Forum say it does. My K100 and my wife's istD are about equal and allow more red to reach the sensor due to a weaker filter. This makes them more sensitive to IR thus can use a shorter exposure with our Hoya R72. I posted IR exposure times for the istD, K100, and filterless K110D a few months ago.
All three camera will produce images that look very red with normal white balance, The sensor is very sensitive to IR and the camera interprets that as red. The Hoya blocks most visible light thus the blue and green channel get a weak signal that "leaks" through the Hoya (which is why it looks black). As mentioned people have success using Custom White balance plus post processing to make a simulated color photo. xs700 has some stunning photos on this thread, but no one expects the trees to look green! The K10D should be easier to compensate since it has less IR red.
Since the Hoya filter is around $44 and a second camera around $350 I'd spend more time with your K10D experimenting. If you like IR but tire of the long exposures then buy a spare camera. But remember the photos won't look MUCH different, just take less time to image. Since pentkon52 said 8-10 seconds for his K10D the exposure time is still short compared to the setup and processing time.
