I like taking low speed shots of water etc but have limited filters to reduce shutter speed. I have looked at the variable density filters but these seem expensive.
I am in the process of moving from Cokin A to Coking P size and have a pair of polarizers. Since I have an A to P adaptor I wondered if I could use these in combination to create my own variable ND filter.
Having mounted them the affect seems to work but need to plan a field trip to test this outside.
Has anyone tried this and have you any tips on this approach?
Once I get outside I will post some results.
