Originally posted by Fritz Here is an explanation of
The DA lens is designed with the crop factor in mind, the older ones are not. At least that is my understanding.
HTH
IF I am correct in my understanding (and that's a big if) Fritz, The DA series is designed with the crop factor in mind ONLY in the fact that they have to cover only the dime and not the quarter in my previous analogy. The DA 16-45/4 is STILL a 16-45mm lens!
Now here is where I may get into trouble. We take a 35mm negative and blow it up to a 4x6, ok? In Kguru's example 12 people are in the frame. Now we put that lens on our 1.5 crop sensor, take the same picture at the same focal length and now only 8 people are in the frame.
Why? Because we took the area of the DIME and enlarged it to 4x6! That's why we say the 50mm is now a 75mm on the cropped sensor camera, but the lens itself has not changed, the sensor changed.
