I was doing some reading, and had come across a couple of threads here that had linked a post from Ken Rockwell. Now, I admit that I usually spend very little time on his site, however this page did get me thinking -
In a nut shell, he made several observations (and provided images), that images from full frame sensors using crummy lenses, are better than cropped sensors using the very best lenses. This is essentially due to full frame sensors having larger pixels that are better able to gather the light.
So, that got me thinking this week. Rockwell used 2 cameras - a Canon 5D (FF/CMOS) with 8.2 micron pixels, and a Nikon D200 (cropped/CCD) with 6.1 micron pixels. Bottom line the FF pixels were about 25% larger. You can go to the link above and see the images and the visual effect.
Pentax, does not have a full frame body. So, I took a look at the pixel sizes on the bodies that I had available - a K100D (CCD) at 7.87 micron pixels and a K5 (CMOS) at 4.75 micron pixels. The K100D has approximately the same pixel size as the Canon 5D. The K100D's pixels are about 40% larger than the K5's. Now there is a slight difference in resolution between the two bodies - K100D at 3000x2008 and the K5 at 4928x3264, but that can be taken in to account (to a degree).
What I did was, to use a single lens for both shots (as opposed to a crummy lens vs a great lens) - in this case a Contax Carl Zeiss 85mm f2.8 Sonnar on both bodies, setting on a tripod, each focusing on the same point 165 feet away (measured via Google Earth's tape measure). Set the ISO to 200, using f8 and focused to infinity (and did get focus confirmation on each body using manual focus). The K100D shutter speed was 4 seconds, while the K5 was shot at 2.8 seconds. I shot both in RAW, and took 100% crops of the same area, then trimmed to a size that would be accepted for a post here.
So how does fat pixels compare to tiny pixels actually fair? - I know, the light could have been better, but it was dark by the time I got home. Anyway, I wanted to see how the K5 did in the evening with the ambient low light that I usually have.
I adjusted for physical size (so I compressed one image), however I did upload the image before compression for a full comparison...
