Originally posted by canajuneh The aurora was dancing last night and is likely going to do a repeat performance tonight. I haven't taken aurora shots in bright moonlight before and wonder if anyone has any helpful hints. How do I set the camera for maximum performance - do I change the ISO from my usual 200-400 - shorten the shutter speed - use a higher aperture?????
Hi. I've nver shot northen lights with a digital, but during the 30 years I lived north of 60 I did lots of film work. i've also done plenty of digital shooting, just not northen lights. Wthout knowing what camera you are using, I have a couple of suggestions.
I suggest that you take advantage of the high ISO performance of your camera, which is almost certain to be superior to film. Experiment to see how high you can go while keeping noise at acceptable levels.
I don't know what you have for lenses. In my experience with quite a wide assortment of fast wide angles I've found that closing down a stop or two results in very significant improvements in sharpness as well as greater DOF. In northen lights photography, this translates to much better rendering of foreground objects such as trees or mountains which are usually required to give northern lights images scale, depth and framing.
If you are working with slower zooms, you can still experiment with juggling high ISO vs. stopping down to see what compromises might work.
i've seen some very fine digital northern lights work, including some going back to the late 1990s. I think the potential is great.
Have fun!
John
