Originally posted by HGMonaro So, without this 5P cable, can you not have the 540 fire wirelessly with no visual impact from the on-board flash?
Yes, you can do that. Set the pop-up flash to operate in "Controller mode" instead of "Master mode" (custom menu), and the 540FGZ is still considered a "Slave" (even when it provides the only source of illumination).
And in this situation, you would be using P-TTL with pre-flash. You get very convenient TTL metering. But your standard optical slave for your Agfatronic would not work properly.
Quote: Alternatively, I could use a "hotshoe to PC" connector I have to fire the Agfatronic and the slave to fire the 540 similar to how I use the Mamiya.
Yes, you can also do that, but you will lose the P-TTL metering.
