I'm staying in Australia for awhile and I've had the opportunity to photograph penguins while a research team collects data on them (weighing, etc). Flash is a no-no for these birds so I tried going off the flashlights being used by the team, a fast lens (55mm f1.4 or 31mm f1.8) and cranking up the ISO. The results, as expected, were less than ideal.
I tried doing some searching but I still have no idea what I could be using to improve the lighting conditions without bothering the birds and still getting decent shots.
I'm thinking if I had some sort of lamp (not a flashlight) that was diffused and soft it would do the trick to get decent shots without bothering the birds. They aren't bothered in the least by the flashlights so I assume a diffused lamp (less focused light than a flashlight) would be fine.
Any tips or suggestions?
