I use an equivalent rule, the "sunny f/8 rule". The sunny 16 rule works well for larger formats, where you often want to shoot at f/16. With smaller formats (such as 35mm) it is more common to shoot at f/8 to lessen diffraction. (Remember the old National Geographic saying, "f/8 and be there"!) So what is the the sunny f/8 rule? It derives from the sunny 16 rule.
First, it is important to note that the sunny 16 rule typically required "rounding off", because typical film ASAs were 25, 50 (or 64), 100, 200, 400, etc. whereas film cameras typically had shutter speed settings of 1/30, 1/60, 1/125, 1/250, 1/500, etc. So we would use the following sunny 16 rule, with the implied settings for f/8 based on simple reciprocity:
ASA 25 => 1/30 at f/16 => 1/125 at f/8
ASA 100 => 1/125 at f/16 => 1/500 at f/8
etc.
In each case the shutter speed at f/8 is 5 times the ASA. This provides a "short cut". Simply multiply the ASA times 5:
ASA 25 => 1/125 at f/8
ASA 100 => 1/500 at f/8
etc.
I still use this rule. With digital cameras it tends to provide an image that is just slightly "dark", which helps to avoid clipping of highlights.
Dan
Reason: Edited for for improved clarity.
