Originally posted by kaiserz I'm also a big fan of the M series, which lens would you suggest for me to get for this kind of shooting? (I'm also going to try to get the takumar 135 2.5)
For thin DOF, a faster lens is (almost) always better. But another way to think of it is as
surgical separation of subject from surroundings. We're trying to make the subject very distinct from their context. This is also called
subject isolation. Maybe it takes a fast lens (highject. FL/AP number), but technique also comes into play. Here again are the basic rules of DOF:
* For
thinner DOF, use a
longer focal length and/or
wider aperture and/or
closer subject distance
* For
thicker DOF, use
shorter focal length and/or
tighter aperture and/or
further subject distance
* Apparent DOF is also affected by subject-to-background distance, and by lighting (keep the BG darker).
I can get thin DOF even with a fairly wide slow lens like a 35/3.5 -- if I shoot from 50cm / 20in away, and the background is at least that far from the subject. Plug some numbers into the
DOFmaster calculator to see how it all works.
_________________________________
What M-type lenses are good here? Some I have and use include:
* Vivitar-Kiron 24/2 -- not cheap, but a fine lens, if the iris blades aren't stuck
* SMC (K) 50/1.2 -- also not cheap, but you already knew that -- can't be beat!
* SMC M50/1.7 -- an all-time favorite -- I hear the M55/1.7 is quite good too
* Takumar Bayonet 135/2.5 -- already on your list -- also try the SMC M135/3.5
I'm sure other fine M-series prospects exist; I just don't have them! Some that are likely available in PK-M mount include:
* Vivitar-Komine 28/2 CFWA (close-focus) -- this is my most-used MF prime
* almost anything in the 24-40mm or 58-100mm ranges that's f/2 or faster
* whatever Helios-44 58/2 version is in M-mount (someone, help me here!)
* almost any 135/2.8 -- most versions from most makers are quite decent
* and longer lenses invariably have thinner DOF, even with slower apertures
All you need is money. Or luck. Or both. Have fun!
