Not sure where to post this, but it might be interesting to some of you so here goes.
Yesterday from inside the house there was some late sunshine and rain and I saw a rainbow, which developed into a double rainbow. I leaned out of the window and took two shots, one was on the K-5 with the Tamron 17-50 and the other was on the IR-converted K-7 with the kit 18-55 on it. Two cameras, two different lenses, and in my haste two completely different focal lengths.
I cropped both very heavily, enhanced the tones and saturation, and blew up the IR one to match. Putting them side-by-side you can see the effect of the 830nm filter in the K-7:
In particular looking at the street light at the bottom left you can see how the IR component of the rainbow is inside the red ring in the color version of the outer ring. You can also see how the outer ring has the colors in reverse order compared to the inner ring.
There's another oddity. In this IR-only shot with a great deal of contrast enhancement you can see bands of brightness inside the main IR ring (the top ring):
The 830nm filter is completely black to the naked eye, so what color is causing those concentric rings at shorter wavelengths than IR?
