04-29-2012, 05:03 PM   #1
Does anyone have an tips for taking pics of Dark Birds?
I am having trouble taking pics of some birds if there is a bright sky behind them if I have a if I lower my Shutter speed I get more details on the bird but everything else is brownout and if I do the other I cant see the bird?
thanks for the help.
04-29-2012, 05:22 PM   #2
jpzk's Avatar
I usually crank up the EV a bit, say 0.3 to 0.7 under those circumstances. It will cause some whitening of the sky but you will get more details of the bird which, otherwise, will be backlit too much.
Slowing down your shutter speed is relative to the lens you use.
For me, most of my bird shots are with the DA*300/4, so I keep the shutter at 1/500s or faster, depending of the available light.
(I shoot TAv, most of the time AF.)
JP
EDIT: And I agree with twitch down below, regarding shooting RAW and using PP to "play" with shadows/highlights.
04-29-2012, 05:24 PM   #3
Ok I will give that a go.
04-29-2012, 05:32 PM   #4
twitch's Avatar
Don't underestimate the value of shooting in RAW, with a good sensor (ie K-5) and raising shadows and recovering highlights in post.
04-29-2012, 05:33 PM   #5
JohnBee's Avatar
QuoteOriginally posted by coreyhkh Quote
Shoot RAW and pull up your shadows.
Couldn't be simpler.
04-29-2012, 05:47 PM   #6
Get a K-5 (or better) and shoot in RAW. A correct exposure should get you all the detail you need
04-29-2012, 05:49 PM   #7
jatrax's Avatar
or better?
04-29-2012, 05:53 PM   #8
or better?
There's more than just Pentax out there, after all A 5D Mk3 would also work wonders, for instance.
04-29-2012, 07:08 PM   #9
jatrax's Avatar
Gosh, and I thought we were trying to convert this to a FF thread.........
04-29-2012, 07:23 PM   #10
imtheguy's Avatar
Sometimes it just takes a little flash and if at distance, a Better Beamer attachement. It can really bring out the muted color, like purple in the feathers, as well as add some highlights. If I can find my sample blackbird shots I will post one here.
Found a sample. I was lazy and just used a flash on the camera instead of mounted on a stand at an angle but you can see how the color appears and highlights so you can play with both in post.
PENTAX K20D  Photo
04-30-2012, 02:11 PM   #11
I am using a K5 and I also only shoot Raw, just thought there may be another trick.
04-30-2012, 03:31 PM   #12
dadipentak's Avatar
My advice is simply, "Don't photograph birds against a bright sky." Unless you can get light on 'em, it's pretty much an exercise in futility in my experience.
04-30-2012, 06:32 PM   #13
Dadipentak is so right!
With a bright background, expose for the bird. Easy to say, "get closer"...birds comfort zone is often way out there where you can't get closer.
First example--expose for the bird and get close as possible. This is uncropped (too soft to handle cropping). Horrid white snow background or bright white sky may be unavoidable.
Second example is "move to where the sky is blue." If you have the option to place the bird against a fluffy white cloud or the blue sky, take the blue sky--unless you can get a bit of both--even better.
Third example is to move back and keep the bird small in the frame (yeah right, like we have the choice!) I shot this Saw Whet Owl a couple weeks ago and had to step back away from it a bit to keep the nearby hillside as background. Any closer and the background was bright white high haze sky. Saw Whets are basically tame and don't care how close you get. With the bird small in the frame, expose for the background and the bird will come out fine.
Remember, with bird photography, your kill rate for perfect frames is very low. If I get a publishable pic or two from any given bird I'm pretty happy...and that's just the birds that let me "play" with them. The vast majority won't even stop to give you a reasoned frame.
PENTAX K10D  Photo
PENTAX K10D  Photo
PENTAX K-5  Photo
04-30-2012, 06:52 PM   #14
hcarvalhoalves's Avatar
That owl shot is awesome! All that detail and the smooth background make it very true-to-life.
05-01-2012, 05:47 AM   #15
TER-OR's Avatar
Overcast day, black cormorants on a dead tree (zoomed 300mm with 55-300). This was just a quick exposure adjustment on the jpg, I hope to have time to work on the RAW files this week:
bird, camera, photography, pics
Looking For Tips For Taking Pics Of Christmas Lights TechGuru Pentax K-r 5 11-27-2011 09:00 PM
Any tips for photographing birds? kinsale Troubleshooting and Beginner Help 30 06-12-2011 09:00 PM
Tips for taking boxing pictures with KX whatamiat Pentax DSLR Discussion 3 03-22-2011 05:19 PM
Need tips for taking portraits with camera facing the sun tnis0612 Troubleshooting and Beginner Help 10 09-14-2010 06:05 AM
Tips on taking Baptism pictures WildSioux Digital Processing, Software, and Printing 2 05-03-2007 05:48 PM
All times are GMT -7. The time now is 08:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
