It's not a desire for more P-modes, and I've left Manual, TAv and Av recently for Program, because I can use Hyper Av really easily and adjusting ISO on the K-5 is simple as anything, so I don't generally find much use for TAv, and only use Manual when lighting is changing rapidly, for stage shows and all that.
I'm thinking about the diea of being able to go straight from P mode to any other mode by turning AV and Tv wheels, instead of the mode dial.
So, say I'm in P mode. Normally, a turn of either dial will take me into Hyper Av or Tv mode. Fantastic, I love this. But I want more.
If I turn the Av wheel, and then the Tv wheel, it aborts Av and goes into Tv instead. I'm saying, why not go into TAv if you adjust the Av and Tv wheel? Giving you a Hyper TAv mode straight from Program.
And then if you're in Hyper TAv, with the press of a button you can go from Auto ISO to fixed, which would obviously give you Manual Mode. Alternatively, fixing the ISO originally, you'd go from Av to Manual by setting both wheels.
So, from P-mode, you can do the following:
P Mode -> Turn Av Dial -> Hyper Av Mode
P Mode -> Turn Tv Dial -> Hyper Tv Mode
P Mode (Auto ISO) -> Turn Tv Dial -> Hyper Tv Mode -> Turn Av Dial -> Hyper TAv Mode
P Mode (Fixed ISO)-> Turn Tv Dial -> Hyper Tv Mode -> Turn Av Dial -> Hyper M Mode
At any point the green button takes you back to P.
And so on.
I just kind of hate the mode wheel. P mode lets me access pretty much all the modes, EXCEPT TAv and Manual, so I'm pining for a Hyper TAv and Hyper M mode.
My K-5 is in it's box at the moment as it's going to the vets soon, but My K-x doesn't let you get from Tv or Hyper Tv to Bulb Mode, this would also be really handy.
HYPER EVERYTHING!
And yeah a movie button would take up room, but it'd be handy. Jump into a movie with your current settings, or the closest possible. Very handy.
