Originally posted by D4rknezz @ Taco
Hahah its true. Except I think it works best only when I have several primes. With several zooms, testing becomes difficult : The variable changes all the time. OO Look! A bird! (135mm zoom, bg at infinity...). Ooo! Look! A phone booth! (50mm zoom, bg at 2 feet away...)...
If i kind of get the math, I figure I can restrict my focal length choice to a specific size, and my background choices too. Also...sometimes its just timing. I am at my day work till dark...then at the weekend...I shoot in studio or do post processing. Too much working with camera to experiment with it! LOL.
@Lowell... I think I asked beyond my capability to comprehend
Please walk me through
I think what you are saying is that despite the relative difference between me - subject - bg, for the same field of view i should still get the advantage of the longer zoom because of the size of the aperture. I still have in my mind that there must be a limit to this, like a 1000 mm zoom vs 50mm , if trying to get the same fov.
Anyway, my confusion below, bolded :
Thanks so much.
Not sure this helps but here goes.
The vertical axis is distance, with the subject at perfect focus, i.e. circle of confusion = 0.
Lets assume you find that for the subject at 10 feet for a 50mm lens, the background is out of focus to the extent you wish, with the background 5 feet back, at say 15 feet, and the lens at F8. That has the projection of the circle of confusion at .04mm in diameter.
What you want to do now, is to shoot the same subject with the same field of view, using a 135mm lens. First of all, since the focal length is 2.7x that of the 50mm, the subject must be 27 feet away.
if you look at the set of lines coming out of the 27foot point on the Y axis, these represent the different apertures of the 135 lens. you want to pick an aperture that will give you the same circle of confusion projection of 0.04 mm so if you look at the grid, and the vertical grid line at 0.04 for circle of confusion, any line cutting this, will for the corresponding lens, give you the Aperture and distance to background for the same level of blurriness. Agail, if you take the line for F4, it shows the background just under 32 feet away or 5 feet behind the subject.
What I found interesting here is that if you keep the shooting aperture the same, you achieve the same degree of blurriness with the same subject to background distance, irrespective of focal length, as long as you always shoot the same field of view at the subject, i.e. maintain the same image magnification. Maybe that's why it is so easy to move back and shoot with a different focal length, there is no calculation. If F4 and a certain setback of background works, moving back proportional to change in focal length changes nothing (at least in the first order. Actually, longer focal lengths have slightly less DOF as a function of magnification, for any aperture. you see this playing with a DOF calculator, as I did for generating the data here
