First, let me say that I'm very respectful of Michael H. Reichmann and thankful for Luminous Landscape. But I was just doing some digging and came across this article:
DOF2
And while I won't take issue with the technical aspects (although I think the demonstration isn't complete enough to prove it), I think he's missed the point. Effectively, any discussion about DoF is subjective, and to my eye, you can see an obvious difference in focus just between the 400mm and the 200mm!
Granted, this is probably not due to a change in DoF, but the simple fact that in the image from the shorter lens the tower is smaller and thus will obviously appear "sharper" (because the eye can only resolve so much). The only way to really confirm the DoF would be to make an enlargement where the tower from the 17mm is the same size as the tower in the 400mm image -- and the result would be essentially academic anyhow because, after all, no one would actually to crop a 17mm image that severely.
Thoughts? Am I just being picky? Okay, yes, I am -- but because I think he started it by saying "Most photographers [are wrong]."
Reason: typo
