Originally posted by wsteffey This afternoon I photographed a passion flower first in JPEG, then a second time in RAW, using my K100d with my Sigma 70-300 APO DG. This evening I processed both in Elements 9.0.
The JPEG required only a little sharpening, using the High Pass method. Nothing else was done.
On the RAW I applied a little clarity, a little vibrance, and a little sharpening. Nothing else was done.
I then converted the RAW image to JPEG and pasted it onto the JPEG image. I then erased the right side of the JPEG layer, allowing the RAW layer to show through. I then flattened the layers and saved for web. The left side of the posted image is the portion shot as a JPEG, the right side is tAmon n shot as RAW and converted to JPEG. The seam is vertical, right through the center of the flower. For some reason, the seam shows up on the bottom as a missing portion of a brown stem.
If my editing protocol has a fault will someone please let me know and I'll correct it and try again. In the meantime, I might shoot fewer RAW images.
It's nice that you're making the effort, but all you've demonstrated is that it is rather easy to downgrade a RAW file to match the character of an in-camera JPEG.
I fail to see what that has to do with uitilizing the extra data in RAW images to produce results better than JPEG, which is why most people with substantial experience in digital imaging choose to shoot RAW.
If your goal was to process a RAW file to look like a JPEG, your protocol was correct. If your overall goal in photography is to produce superior images under widely varied conditions, you have missed the point.
It is very simple. RAW files carry more data and can be interpreted more flexibly than JPEG. That's a fact. An expert working with the best available image editing software will produce better images from RAW files than from JPEG. That's a fact too.
Your belief that editing a RAW file in a crippled program such as Elements constitutes a meaningful comparison demonstrates the limits of your knowledge. I commend you for testing things for yourself, and having the guts to offer the results for public discussion, but you have a lot to learn. Buy or borrow a good Photoshop book and see what it is really all about.
If you're happy working with JPEGs, that's fine. Your flower shot is decent. Carry on.
However, speaking as someone who has done digital imaging professionally for 20 years, I see absolutely no point in shooting JPEG when I can shoot RAW. JPEG is a dead end. RAW is one of several areas where you can bring out quaities in images that make the difference between mediocrity and excellence. Excellence takes extra time, effort and knowledge, as does working with RAW files.
I generally avoid RAW/JPEG discussions as I view them as pointless. However, I dislike seeing the blind leading the blind. This one caught my eye, so there you go.
Cheers
John
