Originally posted by Landaris Hi, I received a couple of weeks ago my k10d, 18-55, 50-200, fa 50mm 1.4 and the flash Metz 48 AF1.
I'm super happy with everything, apart for the flash. I don't have a diffuser, so I usually bounce on the ceiling, but it NEVER get the right exposure. Bounced it's usually very underxposed. I know I can compensate, but what's the purpose of p-ttl ? e-ttl on Canon ( I come from a 30d ) was flawless, with the 430ex, bounced or whatever.
Is my flash a bad one, or is it this way with pentax in general?
Reread the flash's owner's manual, and if you don't find an answer there, try this: Set the flash to a particular apeture setting, and make some test exposures. If they're consistantly underexposed, try opening up the lens 1 stop and see if the exposures are any better.
I have a Metz 36C-2 flash unit, and when I set it, and the lens to f8.0, the exposures are about 1 stop underexposed. I simply changed the apeture to f5.6, and now the exposures are fine.
I don't know if there's something wrong with the flash or the communication between the camera and the flash, but opening up 1 stop solved the problem.
By the way, I usually use my flash in auto mode, with the camera in manual mode.
Good luck.
Mike
