This is an article I wrote for Pentax User UK. Hope you enjoy it!
Sports Photography Using A Pentax
If I could give you only one tip it would have to be a quote from Robert Capa, the legendary American war photographer:
“If your pictures aren’t good enough, you’re too far away.”
Sports photography is about getting in tight and seeing the emotion of the players and crowd. That’s why we love sport – the highs and lows.
You need to be as close to the action as possible and that means right on the touch-line, in front of the advertising boards. If you think you’ll need permission contact the club in the week before the game. My advice is to do this anyway out of courtesy. Most clubs are fine with this because you’re going to publicise their team / event, etc. There may be occasion when you need to be affiliated to a sports governing body to gain access to pitch-side. For example, to take pitch-side photos at any Welsh Premier Football matches you need to be affiliated to the FAW (it’s free and it means you can have access to any Welsh Premier match that season).
I’ve put together a few tips and tricks from my experiences of shooting sports with a Pentax DSLR…
Equipment
Camera Body
I’ve been taking sports photos, and supplying the local press too, for the last five years or so, all with a Pentax. The majority of the pics I have taken have been with a K7 and I’ve recently upgraded to a K5. Both bodies have coped with rugby and football, the latter especially. The autofocus is usually okay, but in dark situations the lack of contrast can hinder you a little. The frame rate is certainly quick enough and it means you’ll have fewer photos to edit through and delete later – imagine shooting 90 minutes at 11fps, most pics will go straight in the bin.
Remember – it aint the camera that takes the picture!
Fast Glass?
For most sports the minimum shutter speed needed to freeze the action is at least 1/500th, more likely 1/640th. If you’re shooting outside on a gloriously sunny afternoon and bathed in bright sunshine then f/5.6 or f/6.3 will be fast enough.
But we live in Britain. Those bright and sunny days, especially in the rugby or football seasons, are very few and far between.
Imagine it’s a Saturday in February at 4:30pm. It’s damp, grey and cold. What little sun there was has almost slipped away until tomorrow. The score is 1 -1. Just as the game is finishing the home side throw one last attack up the field…they score the winning goal and you nailed the photo! Everyone goes wild! Shouting and waving their arms in the air!
Including you.
You’ve just seen your blurry, dark, underexposed photo. f/5.6 will not give you the shutter speed you need (unless you crank up the ISO and then they’ll be noisy).
Don’t even try at a floodlit match unless you’ve got f/2.8.
Cricket, however, is only played in the summer on dry days. f/5.6 is going to do the job just fine! Set your camera on a tripod, aim it at the stumps and fire away! Plus the extra depth of field will let you get the wicket keeper and slips relatively sharp too!
There are plenty of other sports that don’t need f/2.8, too.
But, on choosing a lens, personally, I would go for a larger constant aperture over focal length. For example, f/2.8 200mm instead of f/5.6 300mm.
Memory Cards
I use class 10 Micro SD cards with an adapter. The class 10 makes the files write quicker and the camera’s buffer doesn’t fill up so fast. I use Micro SD cards for another reason which I’ll get to later.
Extra Equipment
Two things that make handling Pentax cameras an awful lot easier are:
1) Add a battery grip
2) Remove the neck strap
Pentax DSLRs are small – a huge selling point – but with a f/2.8 200mm lens on the front it makes them feel a little cumbersome. The grip gives the body that little extra size and seems to balance out the camera and lens. Also, most of my sports shots are taken in portrait orientation and the grip makes those much more comfortable.
How many times have you looked through the viewfinder and found the strap in the way? Never? Oh, if it’s just me then forget point two. But, if you’ve been wasting seconds moving the strap it means you’ve missed the shot - and there’s no replay in live sports! I use clips to attach my neck strap and remove it completely when I start shooting.
One last tip on equipment – wear “work” trousers with knee pads. The extra pockets in the trousers are really handy BUT to make your subjects appear larger, taller and more imposing you need to be on your knees. When you shoot from a lower angle the players look better and knee pads are a must!
Camera Settings & Technique
I either shoot in shutter priority or manual.
If the light is likely to change I choose shutter priority (usually 1/640th or 1/1000th). This is when there are clouds in the sky that are likely to blot out the sun every now and again.
If the light is constant (floodlights, all clouds or all blue sky) I’ll shoot manual, keeping my shutter speed as above.
I wont go over ISO 1600 on my K7 or about 5000 on my K5, but I’ll keep it as low as I can get away with, usually about ISO 800.
I generally use centre point for the autofocus and set the frame rate to Hi.
Finally, I’ve disabled the shutter-release for focussing and use my thumb on the AF button on the rear of the camera. This means I can concentrate on timing and leave the AF to take care of itself. My “hit-rate” of focussed images improved dramatically by switching to this method.
As I mentioned earlier, I’m always on my knees when shooting sports as this makes the players look taller and more imposing (knee pads!).
Finally, get in as tight as possible, either in-camera or by cropping your pics later. Only have in the frame enough to tell the story.
RAW or JPEG
I know that this may, and probably will, divide the audience totally. There are some photographers who swear by RAW and sneer with malicious intent at others who shoot exclusively in JPEG. Well…I shoot a mix of both, but never RAW+.
I use RAW if the occasion is really important, if it’s floodlit (noise reduction) or I want to email a shot quickly from pitch-side (I’ll get to that later).
I shoot JPEG if it’s a “normal” match, usually at the highest resolution.
BUT…when I shoot a sports event and will be printing the images on site, I’ll shoot JPEG at 2 megapixels. This speeds up the transfer rate from card to computer and from computer to printer – time is money! 2 megapixels is plenty enough data to make a quality 9x6 print.
Flash?
Never. Unless it’s before or after the game (team pics, etc).
Pitch-side Editing
I always edit on the fly. If a pic looks no good on a tiny 3 inch screen it’s certainly going to be no good on a computer monitor. I know some people never delete in the field “just in case”, but I do. It saves time later.
I’ll usually take about 300 images at a rugby or football match. This is edited down to 150ish pitch-side and further edited down to about 60 on a computer. Why delete so many? Only keep the best. Also, how many appear in the paper? Just that 1 killer pic. That’s all you need.
Facebook
As fast as humanly possible I get my best (watermarked) pics onto Facebook and tag everybody that I can. It boosts advertising and awareness of your camera skills.
Finally…
Why do I shoot RAW (the biggest file size) to ease emailing images at pitch-side? Why do I use Micro SD cards?
Simple, to get the jump on the other photographers.
At half time I scroll through my RAW images and edit the best one(s) using the in-camera RAW converter. Then I save them as a new JPEG at 2 megapixels. I insert the Micro SD card into my BlackBerry and locate the images. The BlackBerry doesn’t read RAW files so I can scroll through them really quickly to find the newly saved JPEG versions. Send them as an email to the press, etc. That way even if there’s another photographer at your event your pics will get there faster and it’s your shots that appear in the paper. Unless, of course, they’ve just read this tip, too!
(If you try this with JPEGs, the phone reads the image and takes forever to scroll through the large JPEG files and the second half begins before you know it.)
I hope this helps you to nail those sports shots!
