02-01-2008, 09:02 PM   #1
auto bracketing
why is it that when i set my auto bracketing it doesn't work? i put it in manual or automatic and hold down the bracketing button, choose 3 frames, choose the number of steps, then try to take the pictures, and only one picture is taken, instead of 3. help!
02-01-2008, 09:14 PM   #2
either hold the button longer or press it up to 5 times quickly afterwards.
02-02-2008, 04:13 AM   #3
QuoteOriginally posted by jnoelle Quote
Bracketing does NOT cause your camera to shoot in continuous mode or shoot 3 times automatically with 1 press. You still have to fire 3 separate shots (or hold down the shuttle in AF-C mode). The camera will shoot each of the shot with different settings (depending on what you are bracketing).
02-02-2008, 08:00 AM   #4
my boyfriend just bought a nikon d200 and it automatically does it, infact i don't think it even releases the shutter 3 times but rather just digitally adjusts to create the other shots, so maybe that's where i was confused. thank you for the information. I was also wondering, do you think it wiser to auto bracket or to put it in shutter priority or aperture priority mode and adjust one stop? when you are using your camera outside of hyper manual, do you use just the green automatic or do you find the other functions more useful?
02-02-2008, 08:28 AM   #5
JCSullivan's Avatar
Yup, that's what I thought too, until The Forum corrected me. My cheap Old did it internally but the Pentax doesn't.
Such is life.
02-03-2008, 05:17 PM   #6
glad I read this because, if I went to use it one day, I would have thought it was broken too!
02-03-2008, 07:18 PM   #7
Gooshin's Avatar
my K100D fires off 3 shots one after another with just 1 press... just have to hold it down, and it changes the exposure and all...
02-03-2008, 07:26 PM   #8
Moderator Emeritus
I prefer to bracket the shots myself. I'll set the camera in Manual and take the exposures as needed. If I'm shooting for HDR then I'll use the auto bracket with camera on a tripod and a cable release and sometimes the 2 second mirror lock up. That's just to ensure that each shot is framed exactly the same.
02-03-2008, 08:20 PM   #9
SpecialK's Avatar
QuoteOriginally posted by Gooshin Quote
Yep. Can't imagine it working any other way.
02-03-2008, 11:35 PM   #10
If you don't know if which setting is best, auto bracketing is a great time saving feature. Obviously, you'd have more control if you choose to do it yourself... if u have the time. So I wouldn't recommend manually bracketing or auto bracketing over one another, it's a style used in different kinds of situations.
When shooting manual, the green button resets the shutter and aperture to a metered reading. I've found it's best use is when I'm switching between a different scene with drastically different lighting. One press and my 1/30 indoor shutter speed will be reset to 1/1000 when I walk back outside into daylight (for example).
02-04-2008, 07:13 PM   #11
assuming you have a K10D press Fn then up and choose drive mode continuous shooting
james
02-17-2008, 10:17 PM   #12
KungPOW's Avatar
So reading this promted me to play with the autobracket. i just found out that the entire "bracket group" can be adjusted with the exposre compensation.
So instead of -1,0,+1, I can move the group to -2,-1,0, or 0,+1,+2.
Love this camera!
02-17-2008, 11:21 PM   #13
Igilligan
Guest
Now I am confused
My K100d clicks off 3 continuous shots with exp bracketing. Adjustable steps starting where you set exp comp. With a single press of the shutter. Is the K10d different than that?
If it is why would it be different?
02-18-2008, 03:48 AM   #14
The K10D does do it with a single press; just make sure you are set to single shot drive mode (otherwise it'll keep shooting after you've finished your bracketed set), set your bracketing for 3 or 5 shots, set the exposure step value and hold down the button - it'll automatically fire off the requisite number of shots with the appropriate exposure shift for each one.
03-29-2008, 10:54 AM   #15
K10D Auto Bracket stopped working
I just noticed that auto bracketing stopped working on my K10D. I know it worked when I first got the camera. One press created three separate versions of the image. No holding down the release or continuous drive mode was required.
The only thing I can think of is that it stopped working after I upgraded to firmware version 1.30.
I have tried all the modes in which it is supposed to function, and tried varying the EV steps and increments, etc. but nothing works. However, Extended Bracket mode (e.g. for White Balance) does work.
I guess the old adage, "If it ain't broke, don't fix it," applies. Has anyone else had this problem? If so, is there a fix other than trying downgrade to a previous version of the firmware?
auto, camera, photography
K20 Auto-bracketing scorpionbowl Pentax DSLR Discussion 4 07-02-2009 02:34 PM
Auto Bracketing on K10D BBear Pentax DSLR Discussion 4 05-17-2009 01:54 PM
Auto-Bracketing with Remote on K10D? Hannican Photographic Technique 10 01-22-2009 07:33 AM
HDR Auto-Bracketing: not with Remote? braver Pentax DSLR Discussion 0 05-31-2008 06:38 PM
HDRI-Auto Bracketing ollio Pentax DSLR Discussion 13 05-31-2008 08:58 AM
All times are GMT -7. The time now is 03:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
