Originally posted by SunValley @interested_observer About finding your way around the stars just make sure your planetarium program has a night mode which turns the screen to black and red so you don't lose your night vision. I usually just bring printouts from Cartes du Ciel in the field and use 'Astronomical Flashlight Free' on my Android phone to look at them.
Pointing a 300 mm lens in the dark will indeed be a challenge. Your night vision will have to be perfect (Allow your eyes to adapt for a good 20 min in the dark). Turn off the lcd screen on the camera, turn off the blue light of the o-gps1 unit (from the astrotracer menu). That way I easily see stars up to magnitude 4 through the viewfinder of my K-30 with my 200 mm f4. To center a star in the viewfinder I use the 'both eyes opened' technique. I move the camera to try to center the star I see with my left eye with the viewfinder's rectangle I see with my right. As the star approches the center of the rectangle sure enough it appears in the viewfinder.
Clear skies!
Thanks for the excellent suggestions! I went out shooting Sunday night. I ran into the blue LED, but did not know that it could be turned off. I had thought about turning off the rear screen, but how would I turn enable Astrotracking - so I just lived with it. I need to read the manual some more. I did manage to capture some reasonable shots. I learned a lot. I did not experiment as much as I should have. I did not know exactly what my take was really going to look like. I should have tried out a lot more than what I did. I posted on the first run
here. Stone has been offering a number of very helpful suggestions, too. Been using my red light,however I need a headlamp - too few hands.
Its going to take a while to get up to the 300. That one is a ways away. Just concentrating with the Milky Way - and post processing.
Originally posted by mikeSF great tips, SunValley!
here is a pano from Saturday up in Sonoma County:
Starry Night
K5, DA15, O-GPS1
with story on flickr:
WOW, just Spectacular!!!! I have a lot of learning ahead of me.....
