Originally posted by hks_kansei As per the title, I tend to have great difficulty with keeping my hands steady at anything around 1/125 or below.
Are there any tips/tricks/excercises to help?
(worth noting, this is with an *istDS, so no shake reduction)
OK, I see the note, first of all, what lenses are you using?
while I wait for the response, I have attached a link, and OK it is with a K7 and shake reduction on, but it is 1/40th of a second with a 500mm lens. what helped me take the shot is no different than what will help you get better shots too.
https://www.pentaxforums.com/forums/lens-sample-photo-archive/164135-pentax-k...4-samples.html
- you need to establish a steady foundation for yourself, with legs apart and slightly staggered front to back. separation will depend on how big you are, but typically 15-18 inches or more, but regardless it must be comfortable
- you need to hold your camera in 3 places, most shooters (those that are right eyed any way) have the viewfinder /camera back in contact with their face, that is one point, the second is your right hand on the shutter, and the third is your left hand supporting the lens, the further away from your body the better.
- tuck your elbows in at your side, as opposed to out flapping like a bird
- press the shutter button slowly, and try not to rotate the entire camera when you do.
- breath out as you are shooting , or slightly before, but do not breath in.
those are the basics. You can also steady yourself against a post, tree or what ever, or rest your camera on/against something solid, but that is for really extreme cases.
as a rule of thumb, you should be able to get acceptably sharp shots at 1 / ( focal length x 1.5) for prints up to 8 x 10 inch. printing bigger may require higher shutter speeds.
