Originally posted by NaClH2O and I don't want to get involved in a quantum/waveform argument) ... it's simply semantic nitpicking
I think it is nitpicking as well.
But hey, Einstein got a Nobel prize for his nitpicking discovery that light isn't an analog medium at all (he got it for the so-called "photo-effect", not "relativity", at a time where everybody else shared your thinking - by the way, today's camera sensors are still based on this effect
). And please, don't disesteem quantum physics. Without, there would be no digital photography, that's for sure. Future progress will come from there.
As far as photon counting is concerned... The situation isn't that bad already: By quantum efficiency (QE) one means how many photons must hit to create one electron charge in the sensor. The quantum efficiencies of the CCDs and CMOS sensors in modern DSLR cameras is about 20 to 50 percent, depending on the wavelength. Top-of-the-line dedicated astronomical CCD cameras can have quantum efficiencies of 80 percent and more, although this is for grayscale images.
The problem now is that the incremental charge (which
is digital) is collected until read out as an analog measure and then back-converted to digital electronically. The read-out happens globally by shifting charges around which is slow and causes cells to become "full" or even "bloom" (CCD). One could add a microscopic digital charge counter to every sensor cell and digitally increment/decrement each time the charge changes, then reading counters like reading RAM memory. This makes the sensor more expensive. Also, to reduce thermal noise one should cool down the sensor with a peltier cooling element (as is done in astro photography). All this isn't done because nobody would pay for it.
Originally posted by NaClH2O digital sensors (as opposed to film) simply do not have the dynamic range that film does. It is the only area that is truely behind film.
I agree if you add "current" to "digital sensors". Theoretically, a digital sensor can by far outperform a film in DR. I hope I made this clear.
Originally posted by NaClH2O HDR is pretty much the last frontier for digital photography
Again, I agree. But as I may have illustrated, the main obstacles are by market, not technology. Because nobody can actually display HDR (monitors and print aren't HDR), there is no real market pressure behind. Digital mirror beamers and OLED may change this in the future, though.
