Originally posted by tibbitts You are nowhere close to needing to worry about the "sweet spot" in optical performance of your lenses. It's usually a matter of technique, and technique for low-light shots of moving objects is difficult to master. At large apertures, it's possible that you might need to tweak your autofocus adjustments, but you need controlled tests to determine that (tutorials for that are here on the forum.) It's more likely that motion blur or simply selecting the wrong autofocus point is the culprit. When people talk about lens sweet spots on the forum, they aren't talking about glaring sharpness differences in almost every case. The differences in most lenses between wide open and a stop or two down are obvious when pixel peeping, but not in typical online photo viewing.
In the not-so-old film days, indoor color was dramatically more difficult than with any digital camera today, and we often resorted to flash. You don't have to just pop up the flash and start blasting away. You can often use bounce flash for far superior results, or if that won't work, you can probably come up with a multi-flash arrangement, at least for situations like special occasions in your home where you can experiment beforehand. There are also some on-camera flash reflector products than can soften the light from a direct flash and make it much more appealing.
Paul
I'll second this.
In the last few weeks was my first trip where I only took DA/FA limiteds to shoot (plus a tokina 80-200 2.8 for longer FL). Now, before I traveled, I tested all my gear for AF (thankfully no big calibration was needed, between 0 and +4) and sharpness (as expected from limiteds and the tokina, they are pretty damn sharp, some more than others, but you get the point).
Now I'm reviewing my shots, doing PP and whatnot...honestly, I'd say that all of my 5.6 shots have been spot-on in the focus department, while I could find problems with probably 60% of my wide open shots (with any lens). How could this be? All of them performed well with the charts?
Well, it it more of "operator incompetence" than the lenses...turns out that the DOF is so critical that a few milometers off here and there's quite a difference. If you want get demanding about it, there's quite a difference between focusing on someone's eyelashes, eyebrows, hairline or the actual eyes...even if their focal plane is just a few millimeters apart. It's almost as critical as in macros (although one would use a much smaller aperture in macros).
We all sort of learn lessons in a hard way (some harder than others), although there is a sweet spot that you can find with charts...real world shooting is a whole different ballgame from charts (specially when you don't have time to properly setup and your subjects are impatient people). Forget about sweet spots and use an aperture that is appropriate for the situation and your level of technique.
