Originally posted by OniFactor yes. it'll affect the color temperature of any light that bounces from the walls and ceiling. an easy solution is to hang white sheets or dropcloths around the area you'll be shooting to get maximum luminance, or black to reduce reflections if you'll be shooting highly reflective things and don't want distracting catchlights
Thanks!! I guess I will have to buy several white sheets and find some way to hang them up on the ceiling and walls. Do you think covering half of the room with white sheets (underneath and above where the backdrop will be) will be sufficient. The room is about 14x10 I believe.
Or is the color cast I would get in the photos something that I could fix with some post processing?
