Originally posted by jatrax Based on my experience with reflectors the aluminum will definitely reflect more light than the white. However, in this situation will it be noticeable?
Most of the light is already heading forward so how much of the total is going to be reflected? 30%? and how much more will aluminum reflect than white, maybe 30%? So using those numbers you get a total increase of maybe 10%. Plug in different numbers and you get a different result.
The only real way to test it on your particular box would be to take a light meter reading with the white and then line with foil and take another reading.
I think in this case it will make a difference but probably not as much as you hope.
Another thought: you used flat white, so you might get some increase by repainting with gloss. But again I think the difference will not be dramatic.
between flat & glossy, you're right; not so dramatic
I'm not sure about foil vs. white and in the link to the experiment BrianR linked to it's noted that some light escapes through the material; not my case since i'm using 10mm thick MDF boards
With that into account; how many stops more do you think the foil will put out, compared to the white interior?
1/3rd, 2/3?
