Originally posted by FrancisK7 Looks like I'll go with a Raynox
Thanks so much for your input!
I'll need a ring to go with it?
How much harder does this make the focus? I've got AB-800 strobes to light so I can shoot at f/16 if I so desire, the 1M dollar question is, do I get a macro rail for maximum sharpness, or not?
The Raynox adapter is specified to clip onto any lens with a 52-67mm filter size. For the D FA 100 (49mm filter size), unscrew the Raynox element from its adapter and screw it into a 49 to 43mm step down adapter. The diopter then screws into the end of the lens like any filter.
Focus is always a challenge with macro, more so with extreme macro. For a studio or lab, a macro rail is highly recommended. You can use very small apertures for DOF, accepting some loss of IQ from diffraction, or you can use the lens at its peak sharpness and focus stack, in which case a macro rail would be invaluable.
Lights cause reflections. You don't need super bright lighting for a static object, just use a longer exposure time. Consider constant lighting rather than a strobe for better control. Either way, constant or flash lighting, you'll want a softbox. You can make your own soft box (light tent) with a sheet of fabric hung over a frame if you don't want to incur any cost.
http://strobist.blogspot.ca/2006/07/how-to-diy-10-macro-photo-studio.html
