02-22-2008, 10:29 AM   #1
montezuma's Avatar
Need help with exposure problems and snow photography problems, urgent please respond
It was snowing an hour ago and I went out to take some shots. I used a roll of film and then switched to my K10d. I took some shots and when I look at the LCD the pictures seem darker than the actual scene. Now is it that the LCD is messed up or is something wrong with my metering system?
02-22-2008, 10:33 AM   #2
travis_cooper's Avatar
Its because of all the snow. The meter is seeing all the bright white and is going to try to drop the exposure to compensate. Usually when shooting in the snow you need to make sure you are metering off only your subject, or just change your EV compensation up a stop or so.
02-22-2008, 10:36 AM   #3
montezuma's Avatar
Ok well is there a way to fix the pictures I already took? And I forgot to ask before what white balance should I use?
02-22-2008, 10:42 AM   #4
wlachan's Avatar
Next time just meter off the snow +2EV.
02-22-2008, 11:48 AM   #5
Gooshin's Avatar
QuoteOriginally posted by montezuma Quote
you can add exposure/brightness using post processing programs...
02-22-2008, 11:55 AM   #6
If you shot in RAW this is pretty easy to fix, you can change the exposure and wb pretty easy. What wb to use initially kind of depends on the situation, but I'm guessing if it was snowing cloudy would probably get you pretty close. If you know how to do custom wb, that would get you right on since the snow is white, hopefully.
02-22-2008, 02:29 PM   #7
Lowell Goudge's Avatar
the best solution I find in the snow is to use spot metering on the subject (usually darker than the snow, and let the highlights in the snow burn out. otherwise you will espose the snow at the middle of your histogram, and be totally messd up
02-24-2008, 05:43 PM   #8
ve2vfd's Avatar
I snow I just push EV +0.5 to +1, and I set the metering to spot
Seems to work ok for me.
Pat
camera, lcd, photography, shots
K7 30 sec exposure problems leadguitarest Pentax DSLR Discussion 6 11-05-2010 03:32 PM
Problems with camera exposure! Pritch Pentax DSLR Discussion 24 07-16-2010 12:08 PM
problems using automatic exposure kx trishytee Pentax DSLR Discussion 8 06-10-2010 10:56 PM
Exposure problems mattmiles Troubleshooting and Beginner Help 11 01-27-2010 10:15 PM
Long exposure problems wombatwal Pentax DSLR Discussion 22 07-24-2008 07:26 AM
All times are GMT -7. The time now is 10:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
