Originally posted by lushdimple11 Hi, can you please share the steps to finetune zoom lenses? The video is about finetuning the AF on prime lenses only. Thank you
The video alludes to it briefly, but basically if a lens needs a different adjustment at different focal lengths, you have to decide do you a) pick your most used focal length in the range and tune to that exactly or b) check different parts of the range and find a value somewhere in the middle of the range. The second option is a comprimise because the focal behavior of a zoom changes, but the camera only has a single value to configure.
So for instance, it you have a 16-85, and at 16 your range is -5 to -10 and at 85 your range is +5 to +10, you could say you have two values -7.5 and +7.5 so the midpoint is 0. But that assume the change is linear. So if you try a few more values, you could average them.
