Originally posted by Na Horuk Hey, welcome! I would also suggest you try a dedicated macro lens before buying a lot of extension tubes and reverse rings. A 100mm macro can be really great for macro (because you don't have to be so close to the subject) and can also be used as a tele and portrait lens.
But it looks like you already have a good plan. The best is to just try it and then buy things according to what you find that you need.
Have you seen this thread?
https://www.pentaxforums.com/forums/lens-clubs/143202-macro-any-means-necessary-club.html
Tripod if it has three legs, monopod if just one.
Hello,
Thanks for replies!
I do have a zoomlens at home, but I dont like using it much because you have to be so far away. I actually want to be close to the little plants or anything else i photograph. Also, backdrop wont be needed, since the pictures will be almost from above making the soil the backdrop, I have taken some testshots with the zoom with bad sharpness just to see how I wanted it to look.
At first I was going to buy a macrolens, and I found the one I wanted but then I forgot to bid and the lens was gone. Thats when I searched the internet for alternatives.
So, if i'm reading ter-ors post right, it might be enough with only a reverse ring. And extra lighting, that I did forget, but is quite an easy fix hopefully. I'm stopping by the photo-store after work, but i doubt they have reverse rings there, so i'll probably need to to order via e-bay.
I'm going to read that thread jatrax linked now, seems like a lot of information! Luckily I have a job where there is nothing to do exept surfing around on the internet. I didnt find that thread when I was googlesearching before, so thank you! And, tripod, now I know, sounds like a robot
