04-10-2013, 04:06 PM   #1
chromo's Avatar
Post your multiple exposures
My K-5, as many other dslr's, have the ability to take multiple exposure shots.
Post your photos here with an explanation of how the photo was taken.
This could be fun as well as tutorial.
04-10-2013, 04:12 PM   #2
Anvh's Avatar
You mean the on camera option with this right?
So the ghost images and such
04-10-2013, 05:37 PM   #3
QuoteOriginally posted by chromo Quote
I have one, I first took a moon with M-200mm, then took the wide angle by da15. As my da15 fell to the ground with the tripod, the image is not very on focus. Just for fun, not a good one though.
PENTAX K-7  Photo
04-10-2013, 06:03 PM   #4
One more, this one is four exposures. K-7's iso is bad. I found that multi-exposure could help reduce the noise.
04-10-2013, 06:18 PM   #5
blackcloudbrew's Avatar
Here's one of my very first efforts at this which I did last week with my K20d.
And oddly enough a triple exposure with my 645n camera on film at nearly the same time. I bumped the camera...
04-10-2013, 09:25 PM   #6
Not a Number's Avatar
With my K10D. Sarracenia oreophila. One was with auto EV enabled. I don't remember which is which.
In a photo class I took back in the 80s we shot a roll of slide film and exchanged it with another student for the multiple exposures. That was fun.
04-10-2013, 10:23 PM   #7
chromo's Avatar
QuoteOriginally posted by Anvh Quote
Yes. On board.
But not necessarily ghost images. If you can get clean ones too.
04-11-2013, 02:32 PM   #8
Ex Finn.'s Avatar
Only multi exposure I have ever done. K5 and 900mm FL refractor.
04-11-2013, 04:41 PM   #9
Sweet shot! That's very cool.
04-11-2013, 06:21 PM   #10
Ex Finn.'s Avatar
Thanks, took some tries to get the timing somewhat right.
04-14-2013, 03:34 PM   #11
chromo's Avatar
multiple exposure is an interesting subject.
If you're trying to create a scene where the subject is repeated but looks like a single exposure is not so easy to get it right.
04-14-2013, 04:31 PM   #12
Ex Finn.'s Avatar
That is right, the camera does a really good job of preventing over-exposure of the total image, if the desired output is like you said, then either a skillful manipulation in photo-shop or the use of light-painting or "stobist" technique might be the way to go about it.
I am too lazy so the in camera worked fine for me.
Cheers.
04-19-2013, 09:57 AM   #13
You can do the "twin" technique. These was used extensively in the 60s television "The Patty Duke Show" where she played identical cousins. Lock the camera down, mask off one half of the image/lens (say the right side). Shoot the scene normally with the actor on the left. Rewind the film. Mask off the other half. Shoot the scene again with the actor on right. If done properly the seam line should be barely noticeable. Cokin has a filter for this.
I could never get it to register properly using my Minolta X-700 film camera. In order to do multiple exposures without rewinding the film I had to 1) tension the film with the rewind knob 2) keep the tension on the film by holding the rewind know while pressing the rewind release and operating the advance lever. No matter what I did there would always be a little movement of the film, throwing the alignment off.
This should be a snap now with my DSLR. I just haven't gotten around to trying. I finally found the filter that I misplaced somewhere.
Cokin Double Exposure Filter Series A A346
Yes, you can do this in post processing but where is the fun in that?
12-14-2013, 11:12 AM   #14
Hi all,
Experimented with multiple exposures on a recent Mexican vacation. Very useful to get longer effective exposure time without ND filters.
Compare the two shots below - a single 13s exposure didn't give me a really smooth sea, but a 5 (I think) shot multi-exposure gave me an even more wonderful result, IMHO.
Single exposure:
Multi-exposure:
12-14-2013, 11:23 AM   #15
Sweet shot!!!
What is the ideal number of exposures for high ISO noise reduction? It seems like too many shots introduce blur from slight shifts in position (i.e. diminishing returns). Is 3-5 good?
camera, photography, post
Multiple exposures and bracketing voyager13 Troubleshooting and Beginner Help 32 05-09-2014 04:20 PM
Question on using multiple exposures with the timer feature Javaslinger Pentax K-5 & K-5 II 4 07-06-2012 01:45 PM
Multiple exposures without the ghostly effects - how? and more to ask ! jpzk Photographic Technique 10 01-30-2012 08:31 PM
Multiple exposures; K-7 clyde Pentax DSLR Discussion 4 07-31-2011 10:21 PM
Multiple Exposures dawsonjm Pentax DSLR Discussion 11 10-09-2007 05:37 PM
All times are GMT -7. The time now is 07:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
