The tripod itself is not something special. You can buy a used surveying tripod with wooden legs on the second hand market for a few bucks. They are perfect. The mount between the tripod and the telescope is very important. I like the Vixen Porta Mount with has slow motion controls for both axis. If you buy it, throw away the tripod which comes with it and replace it with a better one. The mount shown in the video weighs around 3.5 kg and you can attach two optical tubes to it, which is nice if you want to use different focal distances.
Here is a link to a still which I've made between filming the birds.
http://www.photoinfos.com/astronomie/Skywatcher-Pro-ED80/-FaVoStorch20130420-142.jpg
With an APS-sensor vigentting is no issue. In the edges you can notice some fringing, but these are sticks in front of the blue sky which are always hard to get without any color. The aperture of that system is f 7.5. You could use a frontcover with a smaller circular opening, to close the aperture a bit as in the early days of photography.
Long distance shots with long focal distances suffer under the effect of shimmering air and small particles drifting in the air. If a picture is not tack-sharp it isn't always because of the lens. To show this, I've made a video with a 2000mm telescope on a warm day:
Good Telescopes don't have to be expensive. An ED-refractor with a 80mm/600mm lens is very nice and there are some for 400 - 700 $. Look for this one: Sky-Watcher Pro 80ED APO. It usually comes with a case, some eyepieces and more. For photographic purposes you should add a corrector, which enhances the image quality. For that you'll have to pay 200 - 250 $. Try to get these on the second hand market. Astronomers like to change their equipment or go for larger telescopes.
Tom
