Originally posted by paranoia23 i bought a pentax-m 28mm 2.8 for my reverse adapter.
after a few test it seems to be impossible to add detail with extension rings ... and i ask myself why is that ?!
Can you share your pics and describe your setup?
Here is a set I took with extension tubes and a reversed FA50mm f1.7:
Super Macro - a set on Flickr
A few of things...
You are getting very little light so you can expect long exposures. I would suggest you use some supplemental lighting while focusing (in live view, with magnification) because the viewfinder will be nice and dark.
The closer you get, the motion gets magnified as well, so you need a rock solid support system.
DOF is miniscule, only a tiny little slice of your photo will be focus, so you either have to step way down, which still only adds a little depth of field, but not a lot, or you have to use photo stacking.
