Why does the article (and the discussion here) ignore the primary reason that jpeg is not as good as RAW? To me, lossy compression limits the useful life of an image. Sure, a large portion of the photographs that any photographer shoots may get looked at once and then either never looked at again or even discarded.
But for the photos that are keepers, isn't having the RAW image file stored better than the jpeg?
The article only briefly addresses the lossy compression issue, and conveniently does not call it such.
Quote: With JPEG, isn’t a lot of information discarded permanently?
Yes, and so what. Once you have the JPEG what are you planning to do with the RAW data? If you’re doing this for a living, you will deliver the final image to your client and never again touch the RAW file. If you’re a hobbyist, OK, you may want to reprocess the file as an educational exercise or to try out new techniques. It’s like baking a cake – once you have the cake, what do you need the ingredients for? With digital you can make an infinite number of identical cakes.
Yes and so what?
What a flippant attitude toward the subject!
Um, and photography is not like baking a cake either. Even if it was, when one bakes a cake, the ingredients are converted from their individual components to the composite, finished product, i.e., the cake. So finishing the comparison with, "what do you need the ingredients for?" comes up short.
Without the "ingredients" you don't have the cake.
Without all the RAW data from the original image, you will never have that picture, the way it was at the very instant you snapped the shutter.
I can always pull another jpeg from a RAW file, but once a jpeg has been opened, closed, opened, closed, etc. the original photo is long gone.
Provided the RAW images are stored on a stable storage media, they can be opened and closed an infinite number of times with no loss of the original image information.
Quote: We always start with RAW and always end up with a JPEG, . . . .
No, not always. One can pull a tiff or png from a RAW file too, right?
