Buddha, with that magnification, with all due respect to what falconeye said, try it again either bumping up the ISO (but you were already @ ISO800, so maybe not higher then that for cleanliness) or open the shutter if you can, whatever you have to, to keep shutter speed at 1/10 second or faster. What you're seeing is 'blur' of the moving subject. The thing to consider is, the moon moves one full diameter in 2 minutes. The ideal, is to use a shutter speed as fast or faster then the moon will move in one pixel per photograph exposure time. What do I mean...
Ignoring that at this time and at our latitude of year (I'm on LI so near you) the moon travels at what, maybe about a 70 degree angel off a perpendicular line to the horizon, so the vertical pixel size the moon moves in the two minutes is really SIN(70) * "vertical pixels", not 1 * "vertical pixels"... But for ease of explaining...
The K10D has a vertical rez of 2592 pixels. 2592 pixels / 120 seconds = 21.6 pixels per second IF/when you use enough magnification to fill the entire frame top to bottom with the moon. Thus, a shutter speed of 1/25s will be fast enough so that the moon does not move 1 entire pixel during exposure. Faster is alway better ....
Now, in your image at that magnification, if the moon were full, it would be about 1/2 the frame height. So, how many pixels does the moon move in one second at that magnification? 1296/120 = 10.8 ... So a shutter speed of 1/15s will allow for an exposure where the moon moves less than 1 pixel within the exposure time. Any shutter speed slower will "shmear". Sin(70) * 10.8 = 10.15, so 1/10th will work to give you a "sharp enough" image. Even 1/4s as falconeye said will work, but the moon will move about 2.5 pixels during the exposure. That'll serve to actually "thicken-up" the shadows some.
I recently did the same, stacking my TCs and even adding a 1.7x, and had great results my 2nd time, and that's with having to press the shutter manually thus invoke shake. There was "shmear" here too but with the "almost fast enough" shutter, it was pretty "ok":
https://www.pentaxforums.com/forums/post-your-photos/22470-waxing-crecent-lun...tml#post193964 With that shot @ f/3.2, 1/15s and ISO 800, I had a very good exposure. I didn't do any EV comp, and bumped brightness ever so slightly in post in Lightroom; even left contrast pretty much alone. I was surprised. I'll have to commit that to memory.
