I have been asked by a few on here to share my technique for getting my macro photos so here it is.
This is probably going to end up being a multi-part post because really hate typing.
I will start by sharing my equipment set up.
Latest set-up: Pentax K-5 camera with Lester Dine 105-mm macro lens, Yongnuo YN-560 speedlight, Cowboy Studios 6x7 Softbox diffuser.
7-inch Magic Friction Arm:
Amazon.com: BestDealUSA 7" Inch Adjustable Friction Power Articulating Magic Arm for LCD Monitor LED: Electronics L-grip bracket:
Amazon.com: Heavy Duty Photography L Bracket with 2 Standard Flash Hot Shoe Mounts: Camera & Photo Cowboy Studios 6x7 Softbox:
6" x 7" Softbox for Nikon Flash Canon Speedlight for Nikon SB 600 SB 800 | eBay Wireless flash triggers:
PT04
All my shots are hand held I use a milk crate to sit on and always try to keep my flash at no more than 1/4 power for the shortest duration of flash that helps freeze any movement.
I do the move camera back and forth to focus with the lens always at max magnification and always try to get the insect in the focal plane so I can get as much of the subject in focus as I can.
Here is an example of the insect being in the focal plane.
Here is one where I could not get it in the focal plane.
I have figured out that F/16 gives me the best results with my lens and that is where it stays 80% of the time I have shot some at F/18 and F/22 with acceptable results but not as consistent plus I have to use a higher ISO or up the flash power I try not to go over ISO 400 and most are shot at 1/180th sec unless I am trying to let more ambient light in.
Here is an example of a shot where I wanted more ambient light. Shot at F/16 at 1/100 sec
This shot was in the same location but at F/16 at 1/180 notice how the background is almost black.
That is all for today will continue tomorrow.
