Originally posted by arnold Obviously it is impossible to do an incident reading for a whole landscape then
Actually you can do an incident reading for a whole landscape without driving way out there and all points in between, as long as you can get the meter dome into the same light condition as the landscape is in. So if the landscape is in morning sun then hold the meter in the same morning sun and aim the dome toward the camera lens with subject directly behind the dome, just don't create a shadow on the dome with your body or something else. Now the incident meter will use the dome to average the amount of light falling on it and meter against a neutral gray. That is the same average light as the landscape is receiving from the lenses perspective, whether close or far, now it may not be the best setting for say exposing for a certain feature in the middle of the landscape, disregarding the rest of the scene, but that is when a spot meter is better. Where an incident meter really hits its stride though is with flash photography. I have started using an incident meter a lot and it isn't always the better choice for every situation, but it often is more accurate than the reflected readings from the camera. I have noticed much better results and less PP when used correctly to set camera exposure. Your mileage may very though.
