Originally posted by tlong423 Pre-focusing works great for racing sports, but I don't find it particularly useful for many other types of sports (e.g., basketball, volleyball, football, etc.).
I respectfully disagree. Pre-focusing works very well in volley-ball (VB), and I shot of lot of VB players in poorly lighted sport centre.
VB is in fact pretty easy to shoot, because each team is constrained in a 9m by 9m square, and each player tends to play to a dedicated spot (eg outside spiker, deep 6 defense). When I want to shoot VB, I try to sit close to the bench or close behind the net posts. (Not easy of intl matches, but pretty simple in regional matches, especially if you know the teams). A few tricks may help for VB shooting:
- Try to sit close to the side line or behind the net posts.
- Select the position that you want to shoot (1 to 6).
- Guess the typical distance of the player (typically between 3 to 12 m max.)
- Pre-focus the focus ring to that distance (assuming that you pre-calibrated the focus ring distances before).
- Adjust manually using a player shortly prior to the serve.
- Shoot MF + Hi continuous shooting.
- I found that lenses between 50 to 100 mm will give you great shots from the side bench: eg 50-70mm for a couple of players in action, 80-100mm for one player's action
The attached photographs were taken with (a) FA77mm f1.8 in AF-C and (b) VL58mm f1.4 in MF + distance pre-focus. Both photographs were taken from the sideline. (I was standing on the team bench.)
In my case, my favorite lenses for VB are my VL58mm f1.4 and CZ85mm f1.4, Both are fast primes with MF, and they combine great with my older K-7.
Hope that the comment may help.
