Originally posted by 6BQ5 I want my images to turn out in the way as I see the scene with my eyes.
Good luck with that, Boris. The human eye is a wonderful organ and unrivaled for complex features. We look at a scene and re-focus (without conscious effort) on faraway details, wider, closer, darker, brighter, you get the idea.
Now, imagine teaching yourself to use a tool that does many of these tasks, but has mechanical and optical settings, different adjustments for EVERYTHING the eye does, and at best, won't do all of them in the same frame.
All anyone can do is learn (through practice, reading and research, then more practice) to use the tool, the limits of the device as well as the merits.
Part of the system is post processing. It's not the devil some make it out to be, quite the contrary; It is the second phase of the image-creating.
Ideally, a scene is so perfectly balanced in light, color, brightness + shadow, saturation, contrast, hue, texture, detail, composition, subject placement, balance, rendering and many other factors, that we need no PP. How many times out of 1,000 shots do you think that happens? Once, if you're lucky.
So, we download and correct what nature and luck failed to provide.
You will learn to treasure those few captures that need little processing. In the meantime, give nature (and the limitations of the photographic process) a hand.
Also remember, if you shoot in RAW, you can always convert it to jpeg. If you shoot in jpeg, you're stuck with jpeg.
JMO,
Ron
