Originally posted by Lowell Goudge In A mode lenses are accurate because the non linearity I have found as a function of aperture and assumed scatter off the metering surface, is calibrated out. The camera knows in A mode the maximum aperture, and calculates exposures for camera controlled aperture. With manually controlled aperture the camera has only a light value but no knowledge of the actual aperture and since the metering appears to be non linear, there is nothing it can do
Lowell - maybe I'm reading more into this than I should, but it would seem to me that what you are saying is that part of the problem is that when stopped down, the smaller aperture changes the way the metering is done because of the way the area over which the light is entering has changed and cannot be related back to what the lens would be like when fully open. If I'm right or sort of right, does this mean that metering problems would lessen if you could use spot or center focus metering with a stopped down lens?
