Show Printable Version 4 Likes Search this Thread
07-12-2013, 03:35 PM - 1 Like   #1
LaurenOE's Avatar
Micro - Not Macro Photography
I've recently thought about getting into Micro photography. I guess there are two routes, as in add the camera to a microscope - which I have all the Pentax adapters to use a microscope - and the other route is via a bellows and a very rare Pentax Microscope/Royal thread adapter.
I picked up three basic objectives via eBay
Here I am using my ProMediaGear Katana Gimbal as a Microscope stand
Here is the left eye of George Washington's left eye from an American Dollar Bill
Un-cropped image using the 10x objective
Cropped image using the 10x objective
The bellows technique allows me to set up anywhere, and focus on anything, whereas if I use a Microscope proper, I have to use the Microscope stage and put things on there.
For all the "Micro" shooters, any tips on using the "Bellows" technique?
07-12-2013, 03:53 PM   #2
I sure don't have any tips for you, but wish you well in doing it. I have a brand new, still in plastic, in the box, Pentax, Auto Bellows "A" Set. I have never used it, so I will be watching your thread for ideas.
I have been thinking about opening it up, but always just use extension tubes instead.
07-12-2013, 04:00 PM   #3
LaurenOE's Avatar
QuoteOriginally posted by Old Man Quote
If you ever want to sell it, let me know - I'd love to have another!
I LOVE my bellows! I try and use it all the time!
Granted, the extension tubes are easy, and I use them too, but the bellows gives so much more flexibility!
I don't see much Micro photography out on the web without using a microscope, so I hope to get some folks in here talking about this technique!
I'm brand new in this technique!
07-12-2013, 04:34 PM   #4
That's me too. I have not dabbled into using a microscope lens for taking pics, but I know there are a lot of people doing it.
I had a chance several times to pickup the adapters and just never did it. Pentax made a lot of accessories back in the day. I have a lot of them, but some I wish I had, I don't have. Never thought I would have a use for them.
I am going to keep an eye on this thread, maybe someone can school me.
07-12-2013, 04:41 PM   #5
Not a Number's Avatar
Take a look at Ernie Cooper's blog on the subject. Even though he uses Olympus equipment he often uses microscope objectives. Olympus had an adapter for their bellows to RMS (one of the standards) thread objectives. He'll has all sorts of tips on lighting, focusing abd staging.
macrocritters | What's a nice bug like you doing in a place like this…?
And the forums on Photomacrograpy.net covers the subject too.
www.photomacrography.net...Front Page
I did at one time find either an RMS to K mount or an RMS to T-mount adapter as I was looking into this myself. However having no budget to work with that's as far as I got.
07-12-2013, 04:48 PM   #6
gofour3's Avatar
QuoteOriginally posted by LaurenOE Quote
If you are using a bellows the K100/4 Bellows lens is a good idea. It has no focusing ring, as you use the bellows to adjust. When doing more than 1:1 magnification it’s a good idea to reverse your lens, so you will need the Pentax 49mm or 52mm reverse adapter. My best lens for reversing is a K28/3.5, you can get up to 6.72x magnification. It gets really dark in the cameras viewfinder so a magnifier also helps focusing
Phil.
07-12-2013, 04:52 PM - 1 Like   #7
crewl1's Avatar
Have you tried putting the Q on the back end instead of the K-5?
07-12-2013, 04:57 PM - 1 Like   #8
Here's the relevant post from Ernie Cooper's blog
Image stacking: macro photograph of a fruit fly using a yogurt container white box | macrocritters
07-12-2013, 05:07 PM   #9
LaurenOE's Avatar
Cool!
QuoteOriginally posted by gofour3 Quote
Phil.
I've got all the goodies for Macro work, no problem there. I'm trying to go micro, as in using microscope objectives and going super small.
QuoteOriginally posted by crewl1 Quote
LOL. The Q. Maybe I will give it a go when I settle into the K5 workflow. The K5 with it's dynamic range and IQ is very very nice right now. Plus, I can use my right angle adapter on the K5.
07-12-2013, 05:52 PM   #10
The printed version of "The Amateur Scientist's Handbook" contains a chapter on photomicrography(?). While it's geared towards building your own system, and film, it probably has some useful advice on the subject side, if not the camera side. Good luck.
07-12-2013, 07:48 PM   #11
gofour3's Avatar
OK you want real close, then you need the Pentax microscope adapter. The problem is finding a microscope that fits the adapter.
Phil.
E4800  Photo
07-12-2013, 11:45 PM   #12
carrrlangas's Avatar
ok, show us more examples!
07-13-2013, 05:04 AM - 1 Like   #13
baro-nite's Avatar
Photomacrography.net, linked above, is the place to go to learn all about the options, equipment, and techniques involved.
Note that newer microscope objectives are infinity-corrected, requiring a converging lens (AKA "tube lens") to produce good results. The converging lens can be an ordinary camera lens. Objectives come in a bewildering array of specifications, and most types are not particularly well suited to being used directly attached to a camera.
Older microscope objectives can indeed be used on a bellows.
In either case, once magnifications go above 5x or so, DOF is so shallow that large image stacks are needed to deal with most subjects. So you need a very stable rig with fine control of camera and/or subject movements.
For up to 4x you can get good results with a reversed lens. There are very few lenses that allow you to go beyond 4x to good effect, because of the problem of diffraction. As Phil has recommended elsewhere, the K28/3.5 is outstanding reversed. It is sharp just one click down from f/3.5, and the shorter FL allows high magnifications with moderate amounts of extension.
I have a 10x rig, using a 10x objective (infinity-corrected) on a 200mm converging lens (DA*200). Or I'll put the objective on a 150mm lens (M75-150) for 7.5x, as here:
This is the eye-spot from the wing of a Luna Moth, stack of 85 shots.
07-13-2013, 06:20 AM   #14
LaurenOE's Avatar
Phil.
Yep. I already have that adapter...as that is the microscope proper method.
I'm coming at it from a different angle - the bellows technique which Pentax didn't really push.
07-13-2013, 06:23 AM   #15
LaurenOE's Avatar
QuoteOriginally posted by baro-nite Quote
Great shot!
I guess I got lucky then, because the objectives I got off eBay work great with the Pentax K to RMS adapter and the bellows!
I've got some more modifications to do, as using the 40x objective requires a ton more light.
10x, camera, eye, image, microscope, objective, pentax, photography, technique
Thematic Street Photography (No, Not THAT Street Photography) - Share Your Shots of the Roads Sagitta Mini-Challenges, Games, and Photo Stories 5372 15 Hours Ago 05:11 AM
Nikon Micro (Macro) lenses MRHPhoto Canon, Nikon, Sony, and Other Camera Brands 4 06-08-2013 12:28 PM
Not a day for photography p38arover General Talk 15 01-18-2013 06:38 AM
For Sale - Sold: Nikon 105mm f/2.8G AF-S VR Micro Macro deadwolfbones Sold Items 3 11-29-2011 08:48 AM
DIY Macro/micro lens… maybe underwater? Advice appreciated. cadmus Pentax SLR Lens Discussion 9 02-22-2011 07:14 AM
All times are GMT -7. The time now is 08:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
